Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung anunció la línea Galaxy S23 en su evento "Unpacked" el 1 de febrero de 2023. También se anunciaron las nuevas series de computadoras portátiles Galaxy Book3 y Galaxy Book3 Pro.
Is the Samsung S23 Ultra replacement battery 45W?
Hello, on August 6th, I ordered Ifixit's Samsung S23 Ultra Replacement Battery. Is it 45 W ? I am askig because I wasn't able to charge it above 30W (I'm using a 45W charger and a compliant cable) and Ifixit's specification page doesn't indicate this information. It just says that it's an aftermarket product as close as possible to the original and it gives various numbers EXCEPT the wattage.
Thanks for your help.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
@cdd46151 that is absolutely correct. The charge is not controlled by the battery but by the charging circuitry. Batterie's only list the Wh which is the amount of power (in watts) that a battery can supply for one hour.
Your phone supports 45W charging but the actual wattage will always fluctuate. It may start high but then it will settle anywhere between 15W to 30W. All of this is normal behavior for your new battery.
Fue útil esta respuesta?
Puntuación 0
7 comentarios:
Thanks for your quick reply OldTurkey03 ! So I don't know what's causing this but the iFixit replacement battery definitely charges slower than my original Samsung Battery. I know it for sure because I use the same charger with the same cable (a 100w digital cable that shows the wattage in real time) and same ambient temperature. When I said that the maximum I was getting was 30W, it's when the phone is totally shut down, but when it's switched on in the home screen, it charges at 5-8W with peaks at 18W, it never goes above 20W.
It would be nice if :
1/ Other users told me if their iFixit battery has similar issues or works perfectly
2/ iFixit said what exactly differs from the original Samsung battery. Here in France, a small shop sells the genuine Samsung S23 Ultra Battery 80€ but the iFixit replacement battery only cost me 32.95€. There must be some tradeoffs ?
- de
@cdd46151 hm, definitely unusual but lets see what iFixit says. Try to email them at support@ifixit.com or use the customer service form and see if that gets you a better explanation.
- de
support@ifixit.com has just replied and Marie, Customer Representative, told me that "the battery is genuine" (even though the product page states that "This is an aftermarket part. It is not a genuine Samsung part.") :-/ She thinks that I am using a cable or charger that is not compatible with 45W Super Fast Charging :-/
On the comments page, another buyer ("Louis-Philippe A") has just left a comment yesterday stating that the battery sold by iFixit is not genuine and has a bit less power than the original battery.
- de
I have managed to get an Official Samsung Replacement Battery and I can confirm here that it charges faster than iFixit's Replacement Battery.
- Official Samsung S23 Ultra Replacement Battery Charging Power (observed) : 8W-45W
- iFixit S23 Ultra Replacement Battery Charging Power (observed) : 5W-35W (not 20W like I wrote on a previous post)
The observed charging power depends on the ambient temperature and the battery level.
When the battery level is low (~20%) and the ambient temperature cold, my iFixit Battery charging power will max out at ~35W for a very short time then it will slow down (I'm only talking about my battery, other people may get better results) while the Official Samsung Battery will max out at 45W for much longer.
On the other hand, when the battery level and/or ambient temperature is high, my iFixit Battery will charge at a minimum power of 5W while the Official Samsung Battery will be at a minimum of 8W.
- de
Can you tell us pls how did you manage to get the official Samsung battery and how much did it cost?
- de
Mostrar 2 comentarios más
Añadir tu respuesta
CDD estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 44
Todo El Tiempo: 983
