Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación, manuales y ayuda para la resolución de problemas de Samsung Galaxy A04e. Accede a todo lo que necesitas para reparar tu Samsung Galaxy A04e tú mismo.
My phone takes 8 hours to charge
Why does my phone take too long to fully charge
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Yes and it become not fully charged even if i charged the whole night
- de
@ayabonga did you follow the steps in my original answer? Did you replace the battery? Did you check/replace your charging board? What have you tried?
- de
Yes it takes long hours to charge
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@funnyapollo there are multiple things that can cause this. First thing to check should always be the software. Make sure that your software is up to date and clear the cache on your phone.
The other issues are commonly related to a bad USB part or charging board. Since there are no schematics, replace that board. It is inexpensive and fairly straight forward to change. Double check the ribbon cable form the charging board to the main board. Make sure there are no rips or tears and that the connector is properly working. I would also consider to replace the battery.
If all of that does not resolve the issue, it is possible that your motherboard charging circuitry is giving you an issue. For that your will need the schematic, the board layout file as well as the tools and skills to perform a boardlevel repair.
To work on your phone and since iFixit does not yet have a guide for this, use something like this video. Charging board and battery are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Funny Apollo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 34
Todo El Tiempo: 209
