Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Why is my pc refusing to charge, but it's charger charges other laptos
Charging issues
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
It's a frustrating situation when your charger works fine on other laptops but not on your own. This strongly suggests the problem is with your HP EliteBook Folio itself, rather than the charger. Here's a breakdown of the most common causes and a step-by-step troubleshooting guide.
The Most Likely Causes
  1. Charging Port Damage: This is a very frequent issue. The charging port on your laptop might be loose, bent, or have a broken connection to the motherboard.1 If you've ever had to wiggle the plug to make it charge, or if it feels wobbly, this is a strong possibility.
  1. Battery Issue: Even if the laptop is plugged in, a faulty battery might prevent it from charging or even powering on. The battery may have failed entirely, or the battery's internal charging circuit could be malfunctioning.
  2. Software/Firmware Glitch: Sometimes, a software bug or a corrupted battery driver can prevent the system from recognizing the charger or correctly managing the charging process.2 This is often an easier fix.
  1. Motherboard Component Failure: Less common but more serious is a failure of a component on the motherboard related to power delivery. This could be the power management chip or other internal circuits.
Step-by-Step Troubleshooting
Here's a list of things you can try, starting with the simplest solutions.
Step 1: Perform a Hard Reset (Forced Reset)
This is a very effective first step for many power-related issues as it clears the computer's memory and can resolve temporary glitches.
  • Shut down your laptop completely.
  • Disconnect the charger and all other peripherals (USB devices, external monitors, etc.).
  • If your HP EliteBook has a removable battery, remove it.3 (Many newer models have an internal, non-removable battery, so you may have to skip this part.)
  • Press and hold the power button for 15-60 seconds. This drains any residual power from the motherboard.
  • Plug the AC adapter back in (without the battery if you removed it).4
  • Power on the laptop. If it works, shut it down, reinstall the battery, and try charging again.
Step 2: Check the Charging Port
  • Carefully inspect the charging port on your laptop for any physical damage, such as bent or broken pins, or debris lodged inside.5 Use a flashlight if necessary.
  • If you find any dirt or dust, you can try to clean it gently with a non-conductive object like a toothpick or a can of compressed air. Be very careful not to damage the pins.
Step 3: Update or Reinstall the Battery Driver
A corrupted driver can sometimes be the culprit.
  • Right-click the Start button and select Device Manager.
  • Expand the Batteries section.
  • Right-click on "Microsoft ACPI Compliant Control Method Battery" and choose Uninstall device.
  • Do not uninstall any other drivers.
  • Restart your laptop. Windows will automatically reinstall the driver when it reboots.
Step 4: Run HP Diagnostics
HP provides a built-in diagnostic tool that can check the health of your battery and other components.6
  • Shut down your laptop.
  • Turn it on and immediately press the Esc key repeatedly to enter the Startup Menu.
  • Press F2 to access the HP PC Hardware Diagnostics UEFI.
  • Select Component Tests, then Power, and then Battery Test.
  • Follow the on-screen instructions to run the test. The results will tell you if the battery has failed.
Step 5: Check for a Swollen Battery
For models with an internal battery, a swollen battery can push against other components and cause issues. Look for any bulging on the laptop's chassis (the keyboard or bottom case). If you see this, stop using the laptop immediately and have it serviced professionally, as a swollen battery is a fire hazard.
When to Seek Professional Help
If you've gone through all these steps and the issue persists, the problem is likely a hardware failure on the motherboard. At this point, it's best to:
  • Contact HP Support: If your laptop is still under warranty, this is the first and best option.
  • Take it to a professional repair shop: Look for a reputable shop that can perform component-level diagnostics and repairs, especially if the charging port needs to be replaced or if there's a motherboard issue.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Diana Arunah estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 20
All Time: 331
