Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung anunció la línea Galaxy S23 en su evento "Unpacked" el 1 de febrero de 2023. También se anunciaron las nuevas series de computadoras portátiles Galaxy Book3 y Galaxy Book3 Pro.
Screen not working after battery replacement
I changed the battery because it wouldn't hold a charge...Everything in install went good. I turned it on and Everything powered on, I put it to charge and it's charging good.. So i go to sleep leaving it charged. I wake up and the screen won't power on or anything. But when I do connect a charger it vibrates to indicate it's connected. I try connecting to a laptop but nothing appears but it does vibrate twice when you connect it. I re checked ribbon connections and everything is connected good...Not sure if the screen just went out....Never had a problem with the screen before this.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Same problem happened to me last saturday, but on a Samsung S20 Ultra. After replacing the battery, everything worked OK. I launched a 4k Video to speed up discharging for battery calibration then after a while, the screen started flicking, went black and would not switch on again. When I held the power button, the phone was vibrating, indicating that it was working, but the screen stayed black. I brought my phone to a repair shop that confirmed that the screen had died. It took him 30 minutes to replace it with a new one for ... 150€. Ouch ! But now the phone works perfectly with a brand new Battery and Screen.
I'm wondering if the reason why Samsung stopped selling batteries alone but bundles them with a new screen is because of this problem ? There's no logical reason why someone who wants to replace a battery would also replace the screen unless replacing the battery would under certain circumstances cause damage to the screen (planned obsolescence ? 🤫).
Anyway, I hope you'll fix your problem without having to buy a new screen. Good luck !
PS : On the other hand, I replaced an S23 Ultra Battery the same day and everything went ok (except that the battery charges slower than the original one but it's another problem).
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
miguel m estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 52
Todo El Tiempo: 504
