Saltar al contenido principal
Versión actualizada de la Retina MacBook 2015. Modelo A1534, EMC 2991.
Boot sequence issues and full blast fan while running
Good day, I have a 2016 MBP, battery is dead and i need to be plugged in to use it.
The issue is, i need to press the power button then plug it in to make the MBP start. Then the fan is in full blast while im using it.
Just upgraded to Sonoma via Opencore, works great.
My Main question is; what is the issue when starting the laptop. is there a hardware problem?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Given the systems age I'm suspecting the battery has failed, install this Gem of an App CoconutBattery it will allow you to see mot]re clearly the batteries health. Post a snapshot of the Apps main window here so we can see as well.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Hi @Dan, Yes i think the bat is dead. WIll changing the battery help in booting process issue? and Fan on full blast?
- de
@jujoe - If the systems sensors are telling SMC there is a problem, the SMC logic will lower the CPU's clocking as well as pump up the fans RPM as it's going into CPU Safe Mode. I suspect that is what you are seeing which is likely the Battery, but without proof of seeing the CoconutBattery screen shot I can't tell you it's the battery alone.
- de
Añadir tu respuesta
jujoe1 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 45
