Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información de reparación y desmontaje del smartphone Android Samsung Galaxy A13, lanzado en marzo de 2022.
Samsung Galaxy A13 (SM-A136U) Power Button Replacement
I need to replace the power button on my Samsung Galaxy A13 (model SM-A136U), but I can't find a specific guide or a replacement power button part on iFixit. The button is not working. Has anyone else had this issue or know if the power button is part of another component? Any advice on how to proceed with this repair would be greatly appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
1 comentario:
I had to replace mine and after dropping the phone a few times had issues with it again. Take Sim card slot out and open carefully (ribbon cable is attached from button to board). Take out screws of top plastic piece and gently pry up the clips on side. There is a little metal piece that sits over where the ribbon cable attaches to the board. I have had to pull that out and slightly bend it inwards because the cable wasn't making good connection after dropping it a couple of times. After I did that it worked fine for quite a while. I still have to replace the power button again though because it finally failed. Hop this helps.
- de
Agregar un comentario
2 Respuestas
I didn't find a guide for the SM-A136U, but the Spanish site Nadie Me Llama Gallina has one for the SM-A137. Given they both fall under the A13 model number, I suspect there won't be much difference between them. Anyway, here's how to replace that fingerprint sensor/power button.
Manuals / Samsung Galaxy A13 SM-A137 / Fingerprint and Power Sensor Flex Cable - Nobody Calls Me Chicken
As you might guess, the site is written in Spanish, but if you use it with a browser that includes a translator like Chrome, the guide works just fine no matter what your native language is.
P.S., A little research shows the A137 is a 4G phone, while your A136U is the 5G model. I still maintain there shouldn't be major differences in the procedure between the two.
Update (07/05/26)
Unfortunately, the Nadie Me Llama Gallina site appears to have been taken over and taken down, so the previous link to their repair guide is no longer usable.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thanks, will give it a try.
- de
My phone camera is failed
Puntuación 0
1 comentario:
@davyade, if you have the same phone as the OP, then it has five cameras. Which one failed?
- de
Añadir tu respuesta
westdr1dw estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 30
Ultimos 30 días: 141
Todo El Tiempo: 1,425
