New battery issue. Prolonged charge time and abrupt shut down
I installed a new battery from iFixit (Serial Number: C01514329YEF90NA2). I followed all directions from the iFixit tutorial. Initially the computer seemed to work fine, but now it seems to take forever to charge and then seems to rapidly discharge when it is being used with simple applications. Also it has started to just shut down for no apparent reason. The shut down only occurs if on battery and does not occur if it is plugged in. Is there something I should do to "reset" the computer? Thank you
Update (06/04/25)
Is this is what you wanted? Plugged in and charging.
Thanks for your help.
CooconutBattery indicates Battery Charge 6702 mAh/94%
Battery Overview of [MacBookAir7,2]
Generated on [Jun 4, 2025 at 4:00:25 PM] by coconutBattery 4.0.3
Device Details
Model MacBookAir7,2
Serial FVFXQ453J1WT
Manufacture Date Nov 19, 2018
Battery Details
Serial C01514329YEF90NA2
Manufacturer ifixit
Manufacture Date N/A
Cycle Count 7
Current Capacity (7128 mAh / 7000 mAh)
Health 102%
macOS Battery Status Good
Reported Failures None
Es esta una buena pregunta?
