SIM card door locked
I can't open the SIM holder, it seems to be stuck; how can I remove it to take out the SIM?
I tried using a paper clip, but it doesn't click because it seems stuck.
Es esta una buena pregunta?
This one can be tricky because you dont want to force anything causing damage. Do you have access to a proper sim eject tool? I know a paper clip should and will work, however, I have had this very issue you are explaining. Worst case scenario is that you will need to remove the back and reset the sim eject pin. It's a black plastic pin near the sim tray that looks like a tiny cylinder.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 71
