Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Procesador i5 de doble núcleo A1418 / EMC 3068/2017 / 2.3 GHz. Lanzado en junio de 2017.
Webcam/camera light always on, lights up right when Mac powered on
Noticed this weird issue about two weeks ago that initially had me very concerned, but now just confused: the camera light is always on. It turns on the moment the iMac is powered on, and it stays on all the time. The camera itself still works in apps that use it, and there aren't any camera use requests in the Settings > Privacy section, so I'm led to believe this is a hardware issue, not a software one.
To be sure, I did a malware scan with a couple different apps (Malwarebytes & Webroot) and both found nothing, so I'm pretty sure this isn't software. It's running the most recent MacOS it supports with the most recent security updates, so I doubt it's firmware-related.
I opened it up to check the webcam cable and connectors on the module and motherboard; nothing seemed out of the ordinary, just a slight kink in the cable and the ribbon seems to come out of its connector end at a slight angle (seems like a factory issue rather than damage?)
Any advice on how to fix this? I want to know my options before I commit to buying new parts if they don't actually need replacing.
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Can't answer your question but I have had quite a few issues with Macs over the years, some unresovled, all I can say is that Macintosh hardware has deteriated over time.
I don't think I need remind you to cover the lens with a bit of tape just incase some smart dood has found a way to hide malware from your detection software -- Good luck --
- de
Just wanted to add an update that I did eventually have to just grab a replacement camera assembly, was lucky enough to find one for ~$10 from Wholesale Gadget Parts. Hopefully this helps someone in the future!
- de
Agregar un comentario
1 Respuesta
Solución Elegida
There is a transistor which switches the power to the LED on the camera logic board. You’ll need to pull it off the board and inspect the discreet components for damage or burnt marks. It might be just easier replacing the assembly.
For either non-Retina & Retina models - iMac 21.5" FaceTime Camera
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
0xGarbageCollector estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 39
Todo El Tiempo: 306
