My cluch makes a lot of noise,what could be the problem?
when I press the cluch it makes noise and also when driving
Es esta una buena pregunta?
@sabongankosi you have not told us how old the clutch is and how many miles you think might be on it. In general, this sounds like you either have a bad pressure plate (broken springs, worn clutch lining) or your throw-out bearing is going on the Fritz. I suggest you replace the clutch since it might just be starting to fail.
To check it and to work on it, use the Golf Clutch chapter from on of the many workshop manuals.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 28
Todo El Tiempo: 254
