Saltar al contenido principal
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Preguntas 268 Ver todo
checked everything and still no power
have checked power to everything and still no power, its not the door switch because the inside light is not even on, and the themal switch is good, and i have power to the dryer everywhere it just will not do anything, please help
Contestar esta pregunta I have this problem too
Puntuación 1
Añadir un comentario
Kits de Reparación de Android
Estás a un kit de tu nueva pantalla o batería.
Comprar Ahora
Comprar Ahora
3 Respuestas
Most Helpful Answer
Try unplugging it for 5 minutes to reset it, then plug it back in. Remember an electric dryer runs off of two 110 lines in the USA. So throw both breakers at the breaker box to be sure it's getting full power.
¿Ha sido útil esta respuesta?
Puntuación 3
Your drum light is not a good indication that the door switch is working. Actually, if your door switch is not working, your drum light will not receive any power. Check the wiring diagram on your original question.
Puntuación 2
Comentarios:
Update? My dryer isn’t getting power either
by
Tried everything you recommended and still nothing. Surly someone has solved this problem. Who has the answer. Percy 601-638-1646
Update
checked power to dryer, thermal fuse, door switch all ok. this dryer was working fine one day and nothing the next. No lights or anything just dead.
Puntuación 0
Comentarios:
What symptoms does your dryer have? What have you tied so far? What have you checked?
by
If you already checked all the parts and found them to be in working condition, I recommend a new control panel assembly.
by
How do you test a control panel board, My unit has exact same problem and board loos to the eye as good as new. gordo89120@gmail.com Control board is expensive $180 on Amazon, though it is an easy repair. But costly if that is not the problem.
by
Add your answer
kory hentges will be eternally grateful.
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
Global: 1,653
