Saltar al contenido principal
The Canon PowerShot A710 IS is a compact and feature-packed DSLR released by Canon in 2006. It also comes with numerous accessories to make it an even more reliable machine to take on-the-go.
Preguntas 3 Ver todo
Camera's battery latch broken and it won't turn on.
The camera won't turn on.
The battery door closes but it gets detached easily.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@mehtabsing76021 you will need to try to replace the screws that hold the cover to the mechanism. If that does not work, it is possible that the screws no longer properly hold. In that case, replacing the plastic cover should fix this. This Canon Powershot A720 IS Battery Contacts Replacement should be identical to your camera.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Mehtab Singh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 17
