Saltar al contenido principal
Modelo A1237 o A1304 / 1.6, procesador 1.8, 1.86 o 2.13 GHz Core 2 Duo
MacBook Air 1st gen not powering, no charging light
Hi,
I have a 1st gen MacBook Air here that doesn‘t turn on anymore, but the battery will most likely be dead. But also when I‘m connecting the power cable it doesn‘t turn on and the light on the power cable is always off.
Does that mean the charger is broken or is it more likely that something else is broken?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Mmm… Besides trying a second charger, I would make sure the MagSafe connectors are clean of dirt build up which can interfere with the electrical connections. If the systems connector is in bad shape you can replace it following this guide Reemplazo de la placa de entrada de CC de los modelos MacBook Air A1237 y A1304 the needed DC-In Board is getting hard to find. As it does sound like you never replaced the Battery that is also on the shopping list MacBook Air (Original-Mid 2009) Battery
Before you make the jump in repairing the system, keep in mind this system can’t support newer Apps both because of the macOS it is limited to and the limitations of the hardware with a very limited CPU (Core 2 Duo processor), RAM (2 GB) and either a 1.8” 80GB PATA HDD or 64GB PATA SSD.
Imagen de Replace the 5560 mAh battery compatible with MacBook Air (Original-Mid 2009). 40 Watt Hours (Wh), 7.2 Volts (V).
Producto
$29.99
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Yeah, that‘s the thing I don‘t want to invest much in this old hardware. But I will see if I can find a second charger to test somewhere.
- de
Añadir tu respuesta
Hogardt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 74
