Saltar al contenido principal
Why my wheel stay on transport mode
My wheel stay in transport mode, i have made a spark on motherboard when i tried to change my tire. I tried to take out transport mode with the regular procedure but didn't work. I dont see any sign of burn parts on motherboard, lights and speakers are working
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
It sounds like your Gotway Begode MasterPro EUC is stuck in transport mode, possibly due to a short circuit from the spark you caused while changing the tire. Since your lights and speakers are still working, that suggests the motherboard isn't entirely fried, but there could be an issue preventing it from exiting transport mode.
Here’s what you can try:
1. Retry Exiting Transport Mode Properly
Standard Procedure:
Turn off the EUC.
Place it on a flat surface.
Power it on while holding the power button for 10+ seconds.
Listen for beeps and check if the wheel engages.
2. Check for Error Codes
If your EUC has an app (like Begode or EUC World), connect it to see if it shows any error codes or messages.
3. Battery & Connections Check
Open the EUC and check all wiring, especially battery cables.
Ensure connectors are properly seated and not loose.
Look for any burnt traces or black marks near the spark area.
Try unplugging and reconnecting the battery carefully.
4. Hard Reset / Power Cycle
Disconnect the battery completely and let the EUC sit for 10-15 minutes before reconnecting.
If your EUC has capacitors, they may need time to fully discharge.
5. Check MOSFETs & Mainboard Damage
Even if you don't see burn marks, MOSFETs or other components might be damaged internally.
If you have a multimeter, test voltage at key points.
A common issue is a shorted MOSFET preventing motor engagement.
6. Firmware Reset / Reflash (If Possible)
If the app allows, try updating or reflashing the firmware.
Some Begode wheels require firmware resets to recover from errors.
If none of these steps work, the spark may have damaged a critical component, even if you don’t see visible burns. A technician or an experienced EUC repair expert may need to diagnose it further. Let me k
now what you've tried, and I can help troubleshoot more!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Michel Pellerin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 97
