Saltar al contenido principal
The ASUS Vivobook S400CA is a laptop made by ASUS with a Windows. This page contains repair and service information related to the ASUS Vivobook S400CA.
Can I reutilize these metalic foils on a replacement LCD cover?
I'm replacing the LCD cover on my brother's notebook, the copper? foil is barely attached to the wifi antenna.
They're supposed to be attached like this:
I want to know a few things:
1 - Can I just reutilize these two metallic foils as is? would the crimples on the copper foil be a problem for that?
2 - What is the best adhesive to use for attaching them to the replacement LCD cover?
3 - What are the actual nomenclatures of those two foils and what are their purpose?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Howdy there OP,
The foil is a part of the WiFi Antenna. Truthfully I coulden't tell you what the nomenclatures for the actual foil is, but I do know you can reuse them as long as theyre not damaged/torn anywhere. You could use some Tesa Tape to mount it.
Imagen de Custom cut rolls of Tesa 61395 double-sided tape for repair.
Producto
Tesa 61395 Tape
$5.99
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thank you very much! I'll try that.
- de
Añadir tu respuesta
Antonio Felipe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 58
