Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación e información de desmontaje para el teléfono inteligente Samsung Galaxy A51 Android. Lanzado en enero de 2020.
Samsung Galaxy A51 knocked my phone into some water
I knocked my phone into some water and grabbed it out instantly, i have a Samsung Galaxy A51, i dried it up as quick as i could there was water in the charging port and the headphones port aswell, it would charge normally but the audio believes that there are headphones plugged in, it has been in a bowl of rice overnight, what should i do??
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @spyrexrs
Check the status of the LDI to see if it has changed colour indicating the water may have penetrated further into the phone. (scroll down and click on Liquid or Corrosion evidence in the link)
If it is red (or even if it is still white) then the phone will have to be opened and cleaned and then tested to make sure everything is still OK
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
Using rice to fix water damaged electronic device is a myth, it doesn't work Rice is for dinner, not repair
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Samsung Galaxy A51 repair guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
SpyrexRS estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 21
Todo El Tiempo: 290
