Saltar al contenido principal
A2115 / 2020 / Procesadores desde 3,1 GHz i5 de 6 núcleos, hasta 3,8 GHz i7 de 8 núcleos. Publicado el 4 de agosto de 2020.
upgrade to any release except mojave impossible after disc change
Hi, how can I upgrade to Sequoia or previous releases an A2115 / 2020 iMac?
I have made this upgrade several times on iMacs easily, but this time I'm getting crazy about this operation.
The new drive is an 870 QVO by Samsung and I have previously split the Fusion drive. (prev. configuration 1TB seagate Hd + 28Gb apple ssd)
I've tried with any OS installers, even with Open Core, but I get the same result: Impossible to verfy the installer, or sometimes installer corrupted...
What can I do? Thanks...
Es esta una buena pregunta?
Puntuación 1
1 comentario
Apple has really cracked down on their os so it could be related to that
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Sadly the hidden Blade SSD is being seen by the OS installer trying to setup a Fusion Drive config. The best way is just to pull it out, I know a big pain! The other option is to create a bootable OS installer which you use to wipe the Blade SSD so it’s not recognized by the OS installer.
So… setup a bootable USB thumb drive by first formatting it to GUID and a Journaled file system (HFS+) copy the OS installer to it and then modify it following this guide Create a bootable installer for macOS
After booting up under it open Disk Utility and delete the partition on the Blade drive and I would format the drive MS DOS and now run the OS installer setting up the new SATA SSD drive
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Pulling down the hidden blade... so much work! :-) I'll try the soft way first thanks...
- de
Hi, Dan... The main problem was this terrible fusion drive, I've split it and put to sleep the "hidden" SSD... but there was the second problem causing the "general error message" with any kind of installer...
One o the two ddr4 ram module was misfunctioning, I've run several times the Apple hardware check but with no errors, so I do it in the old way: I have removed the first module and the Imac did not start, instead with the second one everything was running fine.
The problem is now completely solved and the customer is happy...
Thanks a lot...
- de
@ugopagotto - Happy you found that second problem!
- de
Añadir tu respuesta
Ugo Pagotto estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 104
