Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzada el 23 de junio de 1996, modelo NUS-001, la N64 es la primera consola de juegos de 64 bits de Nintendo y, hasta el lanzamiento de la Switch, la única (la GameCube, la Wii y la Wii U podían realizar cálculos de coma flotante de 64 bits, pero esto no es una arquitectura de 64 bits real).
N64 Powers On, No Output, Voltage Tests OK
Background:
A client brought me his N64; his little kid broke the yellow plug of his composite cables at the TV, and now the console won't output at all (lamp on, no video, no audio).
Testing:
I've tested it with multiple cables and can confirm the issue. Gone through the following steps:
  • Cleaned inside and underneath the cartridge slot connector;
  • inspected all pins of each IC;
  • cleaned and tested continuity of AV port pins
  • Tested voltage at 12V and 3.3V rails
  • Tried different expansion/jumper paks
  • inspected capacitors
  • Tested voltage at each pin of the AV port (except RGB & Sync which tested 0 of course because it's not a modded system)
All tests were OK. Not sure where to test further. I'm leaning towards a combination of recapping (which I would've done anyway) and a new cartridge connector. Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hi there!
I think a recap isn’t a bad idea. It’s good to do this anyway! Replacing the pin connector is a goid 2nd step. If all of those things didn’t worked, then it must be something around the AV port..
Please let us know how it goes!
Fue útil esta respuesta?
Puntuación 1
It turns out, it was the client's aftermarket (no-name, of course) power supply.
I opened up my own N64 and swapped cartridge connectors to see if the client's would work on my console, and vice versa. To save time, I just used my PSU to test both consoles. When both consoles worked, that's when it hit me.
I had ruled out the PSU because it appeared I was getting the voltage I needed; apparently not.
Puntuación 0
1 comentario:
Ah interesting! Never expected that this could be the culprit. Thanks for letting us know!!
- de
Hopefully, the multilayer PCB is not going to be a problem.
I would start at the output and retrace using a Oscilloscope to find the video sync signals.
Puntuación 0
Añadir tu respuesta
T.O. Massey estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 50
Todo El Tiempo: 656
