Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1312 / Mediados de 2010 / 3.2 GHz Core i3 o 2.8 y 3.6 GHz Core i5 o 2.93 GHz Core i7, ID iMac11,3
Converting the system into a display
HI, Dan. My interest was primarily forward-looking. I currently am using a 27" iMac (Mid 2010) and anticipating it's demise.
Thinking about acquiring a Mini, but really like the 27" display, so when I stumbled across this thread, thought I'd explore further. (I'm using this thread because I didn't think of asking a separate question.) I'm not a "hobbyist" or computer expert, but do have some experience on electronic devices in general, so... Hope I didn't mess up this thread; it certainly wasn't my intention to hijack it, I just didn't know any other way to contact you.
Es esta una buena pregunta?
Puntuación 0
7 comentarios
@danj, can you point us in the right direction for obtaining the interface board you mention above? TIA!
- de
@doug12716 - Answers (here) is where a collection of volunteers help people.
This series still has a useful life as a computer! Just by updating its OS. I can see other older systems which make sense converting as the last option, and I can see a dead system might be a good candidate as well.
Both directions serve the goals of reuse, but clearly in this case saving the system was the better choice.
Dropping is as you did without context (or better asking your own question independently) means we are left not understanding what your point was.
Yes, GitHub is not the easiest place to navigate or find help, which is why we have a guide on OpenCore! And the PC doc I also linked too often answers the deeper questions.
- de
@doug12716 - I’ve moved your question into its own question so we don’t distract others as the conversion kit is different for the older systems from the 5k display the other system had.
- de
@doug12716 make sure that you get a high quality driver board. Biggest complaint with these boards is that the brightness is less than what you are used to from your iMac.
- de
@oldturkey03 , how might one ascertain the quality? Price isn't always a reliable indicator, eh? Do you suggest just "googling" the mfgr? (Most electronic items seem to be built in China, so info is often limited...)
- de
Mostrar 2 comentarios más
Agregar un comentario
1 Respuesta
Solución Elegida
For your system you will need this driver board 27” iMac A1312 A1316 A1407 2K LCD Controller Board Monitor Display kit For LM270WQ1 A2 C2 E3 F1 B3 screen driver board and here’s the guide to open your system up to clean out what’s not needed Cómo convertir un iMac Intel 27" EMC 2390 en una atractiva pantalla externa HDMI/VGA 2K
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thank you, sir! Very much appreciated! Have a great Turkey Day!
- de
Añadir tu respuesta
Doug estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 44
Ultimos 30 días: 151
Todo El Tiempo: 2,873
