Saltar al contenido principal
El ¨PSP 3000¨ fue lanzado en los Estados Unidos, el 15 de Octubre de 2008.
Preguntas 20 Ver todo
PSP won't turn on, orange light.
i just recently got a PSP 3000. put memory card and battery in and plugged it in. set it to english from japanese. it worked fine, but then i put an UMD disc in and when i tried to launch it it turned off and won't turn back on. this orange light is on and sometimes when i flick the power switch it briefly turns green, but the screen never turns on. i've tried taking the UMD out, taking the sd card out and taking the battery out. please help me, i just got it :<
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Hi!
Is the PSP modded? If yes, you can press and hold “R” and then turn it on. It should launch the recovery menu. Hopefully this works..
- de
@dan0
hi, i've tried all kinds of button combos.. my psp isn't modded either, or at least i don't think so. i bought it used on ebay, so im not sure... ive tried button combos and SD card/battery removal but nothing seems to work. :< i think it may be bricked? but i thought it wasn't possible with unloaded systems..
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi!
When you press and hold the "R" button, it should load the recovery menu (IF it's modded). So, the PSP isn't modded or it is broken.
It could be a lot of things to be honest. Did you contacted the seller on Ebay and explained to him? Best thing is to return it whenever it's possible.
Otherwise you do need to disassemble the device and check if everything is connected properly and check if all the ribbon cables are fine. Also check the UMD drive and the laser. If all looks fine, then you do need to inspect the motherboard and do some measurement to see what failed...
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
sof estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 23
Todo El Tiempo: 53
