Saltar al contenido principal
La tercera revisión del clásico mando inalámbrico Xbox se lanzó en noviembre de 2020, junto con las Xbox Series X y S. Este mando es retrocompatible con las anteriores consolas Xbox One y PC.
Stick drift after replacing joystick module
I have replaced the right joystick module of an Xbox series controller as it had stick drift, but after replacing it the stick drift remains.
When replacing it I did notice some damage to the board so I’m now wondering if this is the cause, I’ve attached a photo so hopefully someone can let me know if that is likely the cause and if there’s anything that can be done.
Thanks, Luke
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Hi Luke!
It look like that some traces are damaged.. this need to be recovered first. Did you already tried to clean it with alcohol? If it remains, then you do need to repair the traces and try again after!
If it’s still having drift after repairing the traces, then replace it again.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Hi Again! Thanks for getting back to me!
I have tried cleaning it with alcohol already and no luck. Fixing trace damage sounds like quite the ordeal, is it difficult? I’m quite new to soldering but happy to give it a try 😀
- de
Hi! No problem!
Yes, it’s somewhat difficult. You need to scratch the trace with something sharp (or sand it) carefully, until you see the copper! Do this for both sides. Then solder a wire between it. So that a signal can come through again.
- de
Maybe try adding a little bit more solder to those pins. Especially those bottom ones. Not to much tho just a tad
Puntuación 0
Añadir tu respuesta
LukeResells estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 14
Ultimos 30 días: 64
Todo El Tiempo: 463
