Replacement battery won’t charge fully, been on charger 20 hours
Replaced battery with replacement from ifixit. Was at 14% out of the box, charging stalled at 69% for hours and after unplugging and plugging back in it’s stuck after 10 more hours at 74%. Contacts are clean and using OEM Apple charger. What do I do next?
Update (11/03/24)
Update (11/03/24)
This is after unplugging and plugging in several times. It’s been charging for the better part of two days and the charging with wattage goes down from about 5 to 0 if that’s significant. Have never had an issue with temp until putting this battery in. Again I’m thinking it’s just a garbage battery but tell me if you see something different.
Es esta una buena pregunta?
1 comentario
@dsmith32472 what's the temperature of the area where the Macbook Air is located while you work on it? Do you still have the old battery? Why did you replace that one? If you still have it, connect it and see what that is charging with. It is possible that you have received a bad battery. All you have to do is to contact iFixit and they will make it right.
- de oldturkey03
