Saltar al contenido principal
Por qué mi PC en la pantalla se coloca un error code:0xc000098
En un inicio prendo la PC y aparece el error code:0xc0000098
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@kevinanton14025 luckily this does not appear a hardware issue but a software issue. The error 0xc0000098 is usually a corrupted system startup item. Yes, there is always a possibility that it can be caused by a bad HDD as well, but it is less common. You did not tell us which version Windows you are using but I would check on this Microsoft Site for a solution.
Of course you can also try these:
Use Windows Automatic Repair:
  • Insert a Windows installation USB or DVD.
  • Boot from the installation media.
  • Select your language preferences and click "Next."
  • Click on "Repair your computer" at the bottom left.
  • Choose "Troubleshoot" > "Advanced options" > "Startup Repair."
Check and Repair File System:
  • Boot from the Windows installation media.
  • Click on "Repair your computer" > "Troubleshoot" > "Advanced options."
  • Open the Command Prompt.
  • Type the following command and press Enter:chkdsk /f /r C:
  • Allow the tool to check and repair the file system.
Rebuild the Boot Configuration Data (BCD):
  • Access the Command Prompt as mentioned above.
  • Type the following commands one by one and press Enter after each: bootrec /scanos
    bootrec /rebuildbcd
    bootrec /fixmbr
    bootrec /fixboot
  • Restart your computer after executing these commands.
Restore from a System Restore Point:
  • Access the Command Prompt.
  • Type the following command and press Enter: rstrui.exe
  • Follow the on-screen instructions to restore your system to a previous state.
Perform a System Reset or Reinstall Windows:
  • If none of the above solutions work, you may need to consider performing a system reset or reinstalling Windows. Make sure to back up your important data before doing this, as it will erase all files on your system drive.
  • from here
Translation
@kevinanton14025 por suerte no parece un problema de hardware sino de software. El error 0xc0000098 suele ser un elemento de inicio del sistema dañado. Sí, siempre existe la posibilidad de que también esté causado por un disco duro defectuoso, pero es menos común. No nos has dicho qué versión de Windows utilizas, pero yo buscaría una solución en este sitio de Microsoft.
Por supuesto, también puedes probar lo siguiente
Utiliza la Reparación Automática de Windows:
  • Inserta un USB o DVD de instalación de Windows.
  • Arranca desde el medio de instalación.
  • Selecciona tus preferencias de idioma y haz clic en «Siguiente».
  • Haz clic en «Reparar tu ordenador» en la parte inferior izquierda.
  • Elige «Solucionar problemas» > «Opciones avanzadas» > «Reparación de inicio».
Comprueba y repara el sistema de archivos:
  • Arranca desde el medio de instalación de Windows.
  • Haz clic en «Reparar tu ordenador» > «Solucionar problemas» > «Opciones avanzadas».
  • Abre el símbolo del sistema.
  • Escribe el siguiente comando y pulsa Intro:chkdsk /f /r C:
  • Permite que la herramienta compruebe y repare el sistema de archivos.
Reconstruye los Datos de Configuración de Arranque (BCD):
  • Accede al Símbolo del sistema como se ha indicado anteriormente.
  • Escribe los siguientes comandos uno a uno y pulsa Intro después de cada uno: bootrec /scanos
  • bootrec /rebuildbcd
  • bootrec /fixmbr
  • bootrec /fixboot
  • Reinicia el ordenador después de ejecutar estos comandos.
Restaurar desde un Punto de Restauración del Sistema:
  • Accede al Símbolo del sistema.
  • Escribe el siguiente comando y pulsa Intro: rstrui.exe
  • Sigue las instrucciones que aparecen en pantalla para restaurar el sistema a un estado anterior.
Realiza un Reinicio del Sistema o Reinstala Windows:
  • Si ninguna de las soluciones anteriores funciona, puede que tengas que plantearte realizar un restablecimiento del sistema o reinstalar Windows. Asegúrate de hacer una copia de seguridad de tus datos importantes antes de hacer esto, ya que borrará todos los archivos de la unidad de tu sistema.
from here
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
KEVIN ANTONIO RAMOS URIARTE estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 107
