Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Teclado mecánico RGB inalámbrico de Logitech
Charging port broken it won't charge
How do I replace the charging port in my keyboard. I dropped the keyboard while it was plugged in and the middle piece inside the charging port was bent out of place and ever since then won't charge. I tried to move the inside peice back into its original place but that didn't work either.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
@christianr67270 sounds like you will have to do some soldering :-). First off, take some good pictures of your damaged port. It could be Micro-USB or a Type-C port. Next, you will need to disassemble your keyboard. Also not a guide, this teardown should be helpful for that. Once you have to bottom removed, take another couple of good pictures of where the port is located. That way we can see if the traces etc. are still good. Once you have all that, it'll be time to find a replacement. Mouser or Digikey are usually my go-to for parts like that. Only issue is that you will have to search by dimensions since your port will not have a part number etc. Ultimately you'll have to disassemble your keyboard, desolder old connector, resolder new connector :-)
Agregar imágenes a una pregunta existente
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de Logitech G915 Wireless (Clicky)
Guía
Logitech G915 TKL Wireless (Tactile) Teardown
Dificultad:
Moderado
30 minutes
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Christian Rodriguez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 72
Todo El Tiempo: 821
