Saltar al contenido principal
Delgada, liviana y elegante, la Swift 3 es la computadora portátil ideal para trabajar en movimiento. La GPU NVIDIA® más reciente, la CPU Intel® y la batería de larga duración se encuentran dentro de una selección de pantallas: un elegante chasis plateado con una pantalla IPS VertiView de 13,5" con relación 3:2 y 2256x1504 o los colores vivos de una pantalla IPS FHD 16:9 de 14" mostrar.
Acer Laptop: How to fix/prevent screen flickering/freezing/lines?
Hello everyone! I have an acer swift 3 laptop (SF314-51-5831). It has gotten wet multiple times in the past. Another thing is that I often carried it in my backpack up close to my back with the weight of the backpack contents pressing onto the lid, which caused the hinge screws to come loose. When i recently started using it again after a pause the screen was working fine. But then it started to freeze/become grayscale/ only show top third (see attached photos). I have then taken the laptop apart and took all the tape of the EDP-cable to see if it was damaged. It still looks intact. When I connect the laptop via HDMI to an external monitor the picture is clear. When I hooked the screen back up via EDP-cable and gently bent the screen a while in all directions(just fiddling around) the picture was clear again(see attached photos). What causes this problem and how can i fix it? How can I prevent it from returning when I put the laptop back together? It seems to me there is water damage and I need to clean something but what? I don't want to buy a new screen or EDP-cable only if absolutely necessary. The screen panel is an AU Optronics B140HAN02.1. The EDP-cable is an CA4DB 1422-02GG000. Thank you for your answers in advance!
Kind Regards JB
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
To prevent screen flickering/freezing lines always update your software. Run the Windows troubleshooter for any error. Also, perform a clean boot and refresh your system to eliminate this problem.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I actually did a data backup and reinstalled windows and updated it, I can try to update the screen driver, it seems to be a hardware problem, also since the connected monitor displays a clear picture the video signal coming from the mainboard isnt faulty. But thank you nonetheless for your reply!
- de
Añadir tu respuesta
Julian Lorenz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 171
