Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2191 Ver todo
Where is the Wifi antenna located?
So I need to replace my wifi/bluetooth antenna. I have looked everywhere trying to figure this out. I know the 4s has two antennas
Upper
http://www.sw-box.com/iPhone-4S-WiFi-Ant...
Lower
[producto vinculado inexistente o deshabilitado: IF115-012]
I have seen both being referenced as the Wifi antenna in many places.
So which one is the actual Wifi antenna? if neither where is the wifi antenna?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
I broke my wifi antenna cable when replacing front glass... does anybody have a good link for replacing the wifi antenna unit? Thanks!
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
There is no actual wifi antenna.
BUT: as is with the iPhone 4 the big metal shield covering the flex connectors of the display and buttons etc is acting as the WIFI antenna.
If you have no WIFI signal you best check if the metal shield is correctly in place and that all screws are in place. If 1 screw is missing it could cause loss of WIFI as some screws are acting as signal path.
Also make sure that all metal surfaces of this metal shield are clean from anything (i.e. some dirt/oil from handling with hands). To be sure just clean it with alcohol/ipa.
Fue útil esta respuesta?
Puntuación 3
"No antenna for wifi". This is true for iPhone 4, but iPhone 4S does use a separate wifi antenna, not the top bezel. Top screw simply holds the logic board onto the bezel to ensure cellular and GPS signal goes through. so I conclude Gido's answer not helping
The iPhone 4S has a wifi antenna around the headphone jack, it is easy to replace. Open up the device, look for 2 screws beside the headphone jack, one holds the antenna connector bracket, one grounds the antenna, remove them, disconnect the connector and peel the antenna off.
Ifixit has a way too over-disassembled guide calls it "upper antenna". That's the wifi antenna. You can use the guide for reference but don't follow the guide to remove everything
Puntuación 2
i believe it is the top ribbon cable and connector, in my experience, the emi shield acts as an antenna too, the signal wasnt as strong without the shield
Puntuación 0
Holy moly!!! Never has ANY advice in these forums worked, ever, but I am sending this post via wifi. I squeezed the metal around the side, then top, of my 4S and wifi picked up & connected for I even checked the settings. Annoying but good fix. Ty Ty ty
Puntuación 0
Añadir tu respuesta
Zach estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 35,484
