Mi iMac 2011 no prende, no suena nada que hacer para esto? Gracias
Mi iMac 2011 no quiere prender, lo deje como 1 año bien guardado, pero no prende...
Es esta una buena pregunta?
@carlosalbe97273 try resetting the PRAM first :
Resetting Parameter RAM (PRAM)
PRAM stores certain system and device settings in a location that Mac OS X can access quickly. Exactly which settings are stored in the computer’s PRAM varies depending on the type of computer as well as the types of devices and drives connected. To reset PRAM:
1. Shut down the computer.
2. Locate the following keys on keyboard: Command, Option (Alt), P, and R. You will need to hold these keys down simultaneously in Step 4.
3. Press power button.
4. Immediately press and hold Command-Option-P-R keys.
Important: You must press this key combination before the gray screen appears.
5. Hold down keys until the computer restarts, and you hear the startup chime a second time.
6. Release keys.
After that we would need to know if your diagnostic LEDs turned on.
LED Functions
LED #1
Indicates that the trickle voltage from power supply has been detected by main logic board. This LED will turn ON when you connect the iMac to a working AC power source. The LED will remain ON as long as the computer is ON or asleep.
When computer has been correctly shut down, the LED#1 behavior may differ:
• - If a startup event is scheduled in System Preferences > Energy Saver, LED#1 will stay ON
after a correct shutdown,
• - If no startup event is scheduled in System Preferences > Energy Saver, LED#1 will turn
OFF and will stay OFF as long as power cord is connected and AC power source is present.
Disconnecting the power cord and plugging it back will turn back this LED ON , even if
computer is still off.
• After disconnecting and reconnecting the AC power source, this LED could remain OFF if
the AC power source is missing or disconnected, if the logic board is disconnected from the
power supply or from the AC outlet, or if the power supply board is faulty.
LED #2
Indicates that computer is turned on. This LED will be ON as long as computer is turned on (but is not asleep) and power supply and voltage regulators are working correctly.
LED #3
Indicates that computer and video card are communicating. This LED will be ON when computer is communicating properly with video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the backup battery (on front of logic board) may need to be reseated, or the video card might be installed incorrectly or needs replacement.
LED #4
Indicates that computer and LCD panel are communicating. This LED will be ON when computer is turned on and video signal is being generated. If LED #4 is ON and there is no image on display, then LCD panel, LED backlight board, or cables between LCD and logic board or backlight board might be installed incorrectly, or need replacement.
LED Startup Sequence
LED #1 = Power available.
If first LED is not lit:
• Disconnect the power cord from computer, then reconnect it to reset the LED status.
• Verify AC power source.
• Verify known-good power cord is connected.
• Verify cable connection between AC inlet and power supply.
• Verify cable connection between power supply and logic board.
• Verify power supply
Let us know what you find out.
Translation
@carlosalbe97273 prueba primero a restablecer la PRAM :
Restablecer la RAM de parámetros (PRAM)
La PRAM almacena determinados ajustes del sistema y de los dispositivos en una ubicación a la que Mac OS X puede acceder rápidamente. Exactamente qué ajustes se almacenan en la PRAM del ordenador varía en función del tipo de ordenador, así como de los tipos de dispositivos y unidades conectados. Para restablecer la PRAM:
1. Apaga el ordenador.
2. Localiza las siguientes teclas en el teclado: Comando, Opción (Alt), P y R. Tendrás que mantener pulsadas estas teclas simultáneamente en el paso 4.
3. Pulsa el botón de encendido.
4. Mantén pulsadas inmediatamente las teclas Comando-Opción-P-R.
Importante: Debes pulsar esta combinación de teclas antes de que aparezca la pantalla gris.
5. Mantén pulsadas las teclas hasta que el ordenador se reinicie y oigas por segunda vez la campanilla de inicio.
6. Suelta las teclas.
Después necesitaríamos saber si se encendieron tus LEDs de diagnóstico.
Funciones de los LED
LED Nº 1
Indica que la placa lógica principal ha detectado el goteo de tensión de la fuente de alimentación. Este LED se encenderá cuando conectes el iMac a una fuente de alimentación de CA que funcione. El LED permanecerá ENCENDIDO mientras el ordenador esté ENCENDIDO o en reposo.
Cuando el ordenador se ha apagado correctamente, el comportamiento del LED#1 puede variar:
- Si se programa un evento de arranque en Preferencias del Sistema > Economizador, el LED#1 permanecerá ENCENDIDO
después de un apagado correcto,
- Si no hay ningún evento de arranque programado en Preferencias del Sistema > Ahorro de Energía, el LED#1 se apagará
APAGADO y permanecerá APAGADO mientras el cable de alimentación esté conectado y la fuente de alimentación de CA esté presente.
Si desconectas el cable de alimentación y lo vuelves a enchufar, este LED volverá a encenderse, aunque el
ordenador siga apagado.
- Después de desconectar y volver a conectar la fuente de alimentación de CA, este LED podría permanecer APAGADO si
falta o está desconectada la fuente de alimentación de CA, si la placa lógica está desconectada de la
fuente de alimentación o de la toma de CA, o si la placa de la fuente de alimentación está averiada.
LED Nº 2
Indica que el ordenador está encendido. Este LED estará ENCENDIDO mientras el ordenador esté encendido (pero no esté en reposo) y la fuente de alimentación y los reguladores de tensión funcionen correctamente.
LED Nº 3
Indica que el ordenador y la tarjeta de vídeo se están comunicando. Este LED estará ENCENDIDO cuando el ordenador se comunique correctamente con la tarjeta de vídeo. Si los LEDs 1 y 2 están ENCENDIDOS y has oído el sonido de arranque, pero el LED 3 está APAGADO, puede que haya que volver a colocar la batería de reserva (en la parte frontal de la placa lógica), o puede que la tarjeta de vídeo esté mal instalada o necesite ser sustituida.
LED Nº 4
Indica que el ordenador y el panel LCD se están comunicando. Este LED estará ENCENDIDO cuando el ordenador esté encendido y se esté generando señal de vídeo. Si el LED n.º 4 está encendido y no hay imagen en la pantalla, es posible que el panel LCD, la placa de retroiluminación LED o los cables entre el LCD y la placa lógica o la placa de retroiluminación estén mal instalados o deban sustituirse.
Secuencia de encendido de los LED
LED nº 1 = Alimentación disponible.
Si el primer LED no está encendido
- Desconecta el cable de alimentación del ordenador y vuelve a conectarlo para restablecer el estado del LED.
- Comprueba la fuente de alimentación de CA.
- Comprueba que el cable de alimentación esté conectado.
- Comprueba la conexión del cable entre la entrada de CA y la fuente de alimentación.
- Comprueba la conexión del cable entre la fuente de alimentación y la placa lógica.
- Verifica la fuente de alimentación.
Infórmanos de lo que averigües.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 47
Todo El Tiempo: 273
@carlosalbe97273 any sign of life? do the diagnostic LED's come on? What have you checked?
@carlosalbe97273 ¿alguna señal de vida? ¿se encienden los LED de diagnóstico? ¿Qué has comprobado?
- de oldturkey03 Compartir
