Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Una cámara SLR digital de 10,2 megapíxeles de Nikon.
I accidentally flashed a Nikon D300 firmware to an D3000 Camera
I accidentally flashed a Nikon D300 firmware to a D3000 Camera (Probably Bricked)
I broke my gear
I was looking for a firmware Update for My Nikon D3000, but I accidentally Flashed my Camera with a Nikon D300 Firmware. So my Camera is stuck and won't turn on except it keeps on Flashing the AF-assist illuminator.
Should I try Flashing the original firmware? (I don't have the original firmware)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Axebros! First:
  • Do Not Power On: If you haven't already, do not turn on the camera. This can prevent further damage.
  • Check for Recovery Options: Some cameras have a recovery mode. Check the Nikon website or user manual for your D3000 to see if there's a way to restore the original firmware.
Then you can:
  • Try to Enter Recovery Mode:
    • Remove the battery and memory card.
    • Reinsert the battery (without the memory card) and hold down the Menu button while powering on the camera. If it enters a recovery mode, follow any on-screen instructions.
  • Reflash the Correct Firmware:
    • Download the correct firmware for the D3000 from the Nikon support website.
    • Format a memory card on your computer (FAT32).
    • Transfer the correct firmware file to the root directory of the memory card.
    • Insert the memory card into the D3000.
    • Power on the camera while holding the Menu button to see if it recognizes the firmware.
Hope this helps Axebros! Happy camera fixing.
(Formatted for easy reading by ChatGPT 4o. I never write my answer using Ai)
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Hello There!
Thanks For Your submission, I'm sorry but I tried everything you have told me but none of them work.
Also I don't have the Firmware..
- de Compartir
Ah man. I would seem that you camera might be borked (bricked).
You can try contacting Nikon for help, but I don't think that they will be able to do much because this camera is from 2009 (might be 2008. I forgot). as for finding the firmware, you are correct, there are no firmware downloads. Nikon never updated the firmware for that camera. I'm sorry I couldn't help more.
- de Compartir
Añadir tu respuesta
axebros boys estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 45
Todo El Tiempo: 532
