Saltar al contenido principal
Lanzado el 23 de junio de 1996, modelo NUS-001, consola de juegos de 64 bits
turns on, but after there was no signal
I turned on my N64 with cartridge, then It had signal on my monitor.
but, after i turned off N64, and Turned on again, then there was no signal.
The problem is that every time I run my N64, I have to turn the monitor on and off. Is there any way I can get a signal even if I turn the N64 on and off without turning off the monitor?
I tried
:changed new av cables
cleaned cartridge and cartridge slot
take off the jumper pack, cleaned, and reinsert
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi!
I would try to replace the jumper pack for a new one! This often do fix this!
If it's still failing after a new jumper pack, then it is cartridge slot related and this one need a replacement (since you already cleaned it).
But let's try the jumper pack first! Way easier to test as well.
Please let us know how it goes!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
ppunkkyu4 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 156
