Como cambiar la rotula
Cómo puedo reparar mis rotulas y mis puntas
Es esta una buena pregunta?
Es parte de la direccion, es algo que has de acudir a un taller, si lo haces mal por ver un video, es un tema de direccion del auto y es peligroso equivocarse con eso.
Fue útil esta respuesta?
@maykelmora as my esteemed colleague @carloslopez1970 already said, this is not necessarily somethin that you should b doing at home :-) Here is the trick so, on your Stratus you can't change the ball joints.
"LOWER CONTROL ARM BALL JOINT
The ball joint used in the lower control arm of this vehicle is a sealed for life ball joint. The ball joint can not be replaced as a separate component of the lower control arm assembly. If the ball joint is determined to be defective it will require replacement of the complete lower control arm assembly."
and the same for the uppers "UPPER CONTROL ARM BALL JOINT
The ball joint is pressed into the upper control arm and has a tapered stud for attachment to the steering knuckle. The ball joint stud is attached and locked into the steering knuckle using a castle nut and cotter pin. The ball joint is not serviceable as a separate component of the upper control arm. If the ball joint is defective it will require replacement of the entire upper control arm."
That is not to say that we can't provide you with some "educational" information on how it should be done. Check this part Stratus Control Arm of the service manual
Repair is War on Entropy!
Translation
@maykelmora como ya dijo mi estimado colega @carloslopez1970, esto no es necesariamente algo que debas hacer en casa :-) Este es el truco para que, en tu Stratus no puedas cambiar las rótulas.
«RÓTULA DEL BRAZO DE CONTROL INFERIOR
La rótula utilizada en el brazo de control inferior de este vehículo es una rótula sellada de por vida. La rótula no puede sustituirse como componente independiente del conjunto del brazo de control inferior. Si se determina que la rótula está defectuosa, será necesario sustituir todo el conjunto del brazo de control inferior.»
y lo mismo para los superiores
«Rótula del brazo de control superior
La rótula se introduce a presión en el brazo de control superior y tiene un espárrago cónico para su fijación al muñón de dirección. El espárrago de la rótula se fija y bloquea en el muñón de la dirección mediante una tuerca castillo y una chaveta. La rótula no se puede reparar como componente independiente del brazo de control superior. Si la rótula está defectuosa, será necesario sustituir todo el brazo de control superior».
Eso no quiere decir que no podamos proporcionarte información «didáctica» sobre cómo debe hacerse. Consulta esta parte Stratus Control Arm del manual de servicio
Aquí tienes una parte traducida del documento Stratus Control Arm.en.es. No estoy seguro de lo bien que se ha traducido, así que puede que tengas que utilizar también la versión inglesa
¡La reparación es la guerra a la entropía!
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 427
