Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Oblo forma parte de la primera serie de Nescafé Dolce Gusto, una máquina de café expreso/sistema de cápsulas de Nestlé, fabricada por Krups. Se reconoce fácilmente por su forma redonda y su palanca manual para activar el frío y el calor.
The machine switches off when starting
The heating element works. The pump works fine with cold water, but when I switch over to hot, the whole machine shuts down after about 1 second. I have tried descaling, although not easy to do with so short pump bursts. Any ideas?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
My idea: because the fault appears when heating, the heater has a electrical short. Open the machine and find the heater. You can measure its resistance, it should be around 40 Ohms for a 230 V machine. If not, replace it.
Another possibility: the issue is a broken capacitor on the motherboard, find the motherboard. The capacitor should look like these e.g. in Nespressos. Replace it, (or both, If there are more) hopefully this will do the trick.
Imagen de Nespresso CitiZ Condensatores
Guía
Nespresso CitiZ sustituir condensadores
Dificultad:
Moderado
Imagen de Dolce Gusto Oblo Junta del conjunto conector del tanque de agua
Guía
Reemplazo de la junta del conjunto del conector del tanque de agua de Dolce Gusto Oblo
Dificultad:
Moderado
40 minutes - 1 hour
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thanks VauWeh, it was the capacitors. I changed them a couple of years ago, but the symptoms then were different (must have been the other one, there are two) so I didn't think that was the problem. Anyway - it works - hurray!
- de
Congratulations! Repair is war on entropy!
- de
Añadir tu respuesta
Olle estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 22
Ultimos 30 días: 120
Todo El Tiempo: 1,592
