Saltar al contenido principal
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
Preguntas 73 Ver todo
How Do I Put Movies On My PSP?
I Have Movies That Downloaded On The Internet And Is On My iTunes And I Want To Put It On My PSP But Everytime I Put It On My PSP It Says Unsupported Data So Am I Doing Something Wrong Can Someone Tell What To Do.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
10 Respuestas
Solución Elegida
Convert them to AVI or MP4.
Fue útil esta respuesta?
Calificación 3
Comentarios:
Good answer. You can use FFMpegX, or other free, available converters.
por
convert it to avc or mp4 480x270 for psp 1000 best way other doesn't support. if u need to run any video format on ur psp 1000
u need to download PMPlayer Advance for psp
Calificación 0
You can convert the iTunes M4V videos to AVI or MP4 which are supported by PSP. You can customize the video bitrate, video size, etc.
Calificación 0
Maybe movies' format is not compatible with your PSP, you can go to try kigo video converter, it is a completely freeware, I always use it. Hope can help u, thx.
Update
Yes, I got confused, videos you got from iTunes are M4V format with DRM protection. If you want to put your videos to PSP, you should convert M4V to MP4 firstly. You can go to try M4V Converter Plus (www.m4vconverterplus.com). And you can put converted files to PSP.
Calificación 0
PSP support MP4, AVI file, you need to convert downloaded video to mp4 or avi for importing to PSP for playing. if you need hope this can help you http://www.firecoresoft.com/mp4-converte...
Calificación 0
Take it easy, you just need three tips: import movies from iTunes to the M4V to MP4 converter, customize output profile, start conversion. How easy it is! You can learn more at [ http://www.m4vconverterplus.com/m4v-mp4-...|M4V Converter Plus]
Calificación 0
One video converter can help you to convert any movie to .mp4 format,and then you can transfer the video to mp4.Try this free soft ware free mod converter
Calificación 0
iTunes video have DRM-protection, so need to convert iTunses to other formats that can be played on PSP. I ever used a tool named M4V Converter Genius to convert iTunes video to my PSP 3000.
Calificación 0
iTunes M4V is a video container format developed by Apple and is very similar to the MP4 format. But M4V files may optionally be protected by DRM copy protection. Apple uses M4V to encode video files, such as TV episodes, movies, and music videos, in its iTunes Store.
If you want to watch them on PSP, you need to remove the drm first. There are many programs that can do this, I always use Adoreshare M4V Converter. You can try
Step 1. Import M4V Video Files
Step 2. Select Needed Output Format
M4V Converter Genius provides 6 categories for you to locate needed output format more easily: Recent, Devices, Video, Web share, HD & 3D, Audio.
Step 3. Specify Output Folder
By default, all converted videos are saved in a folder named "Adoreshare". You can also set another output folder by clicking the browse button.
Step 4. Start Converting
At last, click on Convert button in the bottom right corner to put an end to the whole conversion. The process bar will be displayed with the number of videos that are being converted.
Calificación 0
The easy method that I have tried to convert iTunes drm protected m4v video to unprotected mp4 is to use third party software-M4V Video Converter. We all know that iTunes movies and TV shows are encrypted with drm protection. So these iTunes m4v files can be played on Apple devices only. Before you play iTunes m4v files on VLC media player, you need to remove drm protection. Before you follow any way to convert these video, you need to know more about how to convert iTunes video quality lossless. That will ensure the conversion iTunes m4v videos is the same with original videos. You can check more details on this official site. Good luck to you.
Calificación 0
Añadir tu respuesta
Brandon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 7
Últimos 30 Días: 60
Todo El Tiempo: 5,807
