Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Why wifi not connected and not working
Wifi not connected
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@fnkysid there are just to many possibilities to give you a concrete answer. The very first thing you want to do is to go through the Samsung troubleshooting site Follow those directions first.
If none of that is working, then there is a possibility that you are having issues with the WiFi antenna or the WiFi/BT IC on your mainboard. For that follow the troubleshooting flowchart
Measure the voltages according to the flowchart. To identify the location of these components on the circuit board, use the Component Layout and do a search with your PDF reader for the listed number i.e. C3012 and so on.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Fnky Sid estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 148
