Saltar al contenido principal
El primer modelo de iPhone, modelo A1203 con 4, 8 o 16 GB de capacidad y una parte posterior de aluminio. La reparación requiere una cantidad significativa de destreza, y puede requerir un poco de soldadura.
Preguntas 224 Ver todo
Air bubbles after changing screen
I`ve tried to change screen on my iphone 2g, which was full of bad pixels. I bought a new one on ebay and followed instruction video on youtube, but after connecting everything back the screen looked like this(photo). What have I done wrong? Can this problem be solved somehow or I have to buy a new screen?
Thanks in advance
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
Driver733, I am hoping you replaced it as an assembly, not as individual pieces. If you replaced it as an assembly, contact your vendor. This is a manufacturing defect and ask for a replacement or a refund. this is not something that you have done.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thanks for your answer. Here`s the item I bought (http://tinyurl.com/d5h8lfb) The seller told me that it is OEM. Could you please take a look on this item and say if it`s OEM or not.
- de
It is hard to determine if it is OEM or not. This is something that a lot of vendors are saying. The problem here is that air got trapped when the LCD and the glass were bonded. Poor quality control has become a major issue. Hope this helps, good luck.
- de
Añadir tu respuesta
DRIVER733 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 639
