Saltar al contenido principal
Modelo A1103 / 1.25, 1.33, 1.42 o procesador G4 de 1.5 GHz
On start up, I get a kernel panic message.
I have a g4 mini. I am running 10.5. When I start the machine I get a kernel panic after a long white apple screen with no timer. I cannot open from the leopard disc nor can I open in verbose. Could this indicate a drive failure? Or would it be more indicative of a logic board failure.
Es esta una buena pregunta?
Puntuación 1
2 comentarios
How are you trying to start from the leopard disk?
- de
I am starting leopard by holding c at start up. The optical drive reads and then it seems to stall at the white apple screen with the timer turning.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
This is not good. Spray some window cleaner on a soft cloth and clean the installation disk. Then try start from the CD again.
Resetting the Power Manager
If the computer is on, turn it off.
Restart the computer by holding down the reset button to the left of the Serial port for 10 to 20 seconds.
If the computer does not restart, repeat step 2 three or four times.
Resetting the Power Manager and PRAM
Resetting the parameter RAM (PRAM) when the computer is shut down also resets the Power Manager. The following process resets both the Power Manager and the parameter RAM.
Make sure the Caps Lock key is not down.
Restart the computer. Immediately after hearing the startup sound, simultaneously press and hold Command-Option-P-R. (If you do not hold down the key combination within 5 to 10 seconds after the computer restarts, you must repeat steps 1-3.)
Hold down the keys until you hear the startup sound again. Then release the keys.
If the computer shuts itself off, press the reset button on the back of the computer to turn it back on.
When the computer has finished starting up, restore any custom settings.
Get to another mac and start up in target mode. Connect via firewire cable, start the bad machine holding down the "T" key. It should bring the hard drive up on the other machine. Get your data off first. Then run disk utilities. Also check remedies listed on Apple's site for gray screen: http://support.apple.com/kb/TS2570
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Great answer++
- de
That happened to me when my drive was stuffed. but perhaps just try diagnostics by restarting the computer with "option" held down
Puntuación 1
1 comentario:
How will that help? What happens when the option key is held down? I'm trying to help you be a better contributor not insult you ;-)
- de
Añadir tu respuesta
Eric estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 2,402
