Saltar al contenido principal
Versión renovada del iPhone 3G con velocidades de procesamiento más rápidas. La reparación de este dispositivo es similar a la 3G y requiere destornilladores simples y herramientas de palanca. Modelo A1303 / 16 o 32 GB de capacidad / respaldo de plástico negro o blanco.
Preguntas 1500 Ver todo
Getting an unknown error 9. Can't restore the OS.
Hi, I have a week 38 iPhone 3GS jailbroken by blackra1n. Pherhaps it's because I uninstalled a software not so properly. After that, it began the white apple loop. And every time I restored it, it gave the unknown error 9 out... whether in DFU or restore mode. I've changed USB ports, computers, Macs, systems... Same thing. Some are saying it's a hardware problem, probably the flash drive. Has anyone suffered this before? I appreciate for any of your help. Thanks a lot.
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Hello, i have the same problem. It is working with? Finally you could fix it?
- de
I tried everything, did a lot of research, then finally went to the Apple store and they tried everything. The result: my iphone is now an iBrick. This sucks, my 2nd Apple device to die just after a year old. Not getting another.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Try this:
Step 1. Turn off iPhone
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that it’s in restore mode.
Alternative Method:
Step 1. Connect iPhone to USB then listen to the sound when it connects and disconnects.
Step 2. Hold the home and power buttons until you hear the disconnect sound then release the power button.
Step 3. Wait until you hear another sound then release home button.
This is DFU mode. Hope this helps.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
What's DFU?
- de
Device Firmware Upgrade, it's just a fancy term for restore.
- de
Thanks +
- de
Añadir tu respuesta
Yuan Jiang estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 10,823
