Saltar al contenido principal
Lanzado en julio de 2018, el MacBook Pro de 15", modelo A1990, presenta una pantalla de retroiluminación LED de 15.4 pulgadas con tecnología True Tone, TouchID y hasta 6 procesadores Core i9.
Preguntas 210 Ver todo
Bootcamp on headless MacBook.
Hi, everyone I have a headless MacBook it's working great except the display. I want to install windows via bootcamp. The setup wouldn't show on display. The windows logo just blinks. I tried it in clamshell mode, Windows narrator. But I couldn't found any solution. I (can't)don't want to buy a display right know. Thanks for all answers.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Hi Adam, Unfortunately you cannot install Windows without an internal display as Bootcamp needs drivers to output to an external display which you cant install without being in Windows.
This is the knowledge I possess so I could be wrong.
Best of luck, BetaTech Labs Repair AU
Fue útil esta respuesta?
Puntuación 0
6 comentarios:
@betatechlabs Hi, thanks for answer. Would making a custom ISO with drivers work?
- de
@betatechlabs I tried this https://transferx23.medium.com/adding-cu.... But it didn’t work. The new iso I created had 6gb after “adding" 8gb of drivers to 6gb iso. So had to do something wrong.
- de
I think somebody more experienced should made the custom iso and download link for it. Also with a Ifixit guide. Because for this problem, there isn’t any solution anywhere.
- de
@kicmer Yeah I don't think you can make an ISO like that.
- de
Mostrar 1 comentario más
i think you should try something like usbc-hdmi hub. known working one would be UGREEN and Anker, but i believe almost any will work. the trick is that dp-alt mode is supported by efi, so you do not need windows explicitely to support anything. at least such adapters show picture right in the efi mode, which means they are not OS-dependant.
Puntuación 0
4 comentarios:
The problem is that this can get expensive quick as docks that support efi video out can cost about $80 USD
- de
I got this one from Baseus. And I don’t think that it support efi.
https://www.baseus.com/products/6-in-1-u...
- de
it might, you can always try.
- de
try UGREEN Revodok, thats 20$.
- de
Añadir tu respuesta
Adam Kiršner estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 29
Todo El Tiempo: 90
