Mi lapto se apago y no prendio mas
La lapto se apago y no prendió mas
Es esta una buena pregunta?
¿has comprobado si el alimentador saca voltaje ? ¿cuando se apago estaba al minimo de carga de baterias?
Fue útil esta respuesta?
@juancarlos81336 could be a BIOS issue but it can also be a lot of other things, like a power issue. You do want to go ahead and start checking the easy things out first.
Start with the standard troubleshooting. First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Once you have checked this all out, you do want to let us know. IF all of that is normal, check your computer's HDD as well as it's BIOS. One of the main things about this laptop is that it has a dedicated DC-In jack. That is where I would start to narrow things down.
Translation
@juancarlos81336 podría ser un problema de la BIOS, pero también puede ser muchas otras cosas, como un problema de alimentación. Usted quiere seguir adelante y empezar a comprobar las cosas fáciles a cabo en primer lugar.
Comience con la solución de problemas estándar. Primero comprueba la fuente de alimentación. Asegúrate de que tiene los voltajes adecuados. Comprueba que los conectores no estén doblados, etc. Comprueba la toma de entrada de CC del portátil. Asegúrate de que no hay corrosión, suciedad, etc. que impidan su funcionamiento. Límpiala de cualquier resto de suciedad, etc. Utiliza un poco de aire para limpiarla. Si nada de esto funciona, coge un amperímetro y comprueba si tu portátil consume algún amperaje del cargador. A continuación, comprueba si la placa base recibe alimentación. Para eso, por supuesto, tienes que abrirlo. Publica algunas buenas fotos de lo que ves. De esa manera podemos ver lo que ves. Por supuesto, también puede que tengas que plantearte cambiar la batería. Una batería agotada ya no se puede cargar. Sin embargo, no debería impedir que el ordenador se encienda, si está conectado al adaptador de CA.
Una vez que haya comprobado todo esto, le recomendamos que nos lo comunique. SI todo esto es normal, compruebe el disco duro de su ordenador, así como su BIOS. Una de las principales características de este portátil es que tiene una toma de entrada de CC dedicada. Ahí es donde yo empezaría a reducir las cosas.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 14
