Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2375 Ver todo
microphone not working after change of screen
Okay my iphone 4 had a smashed screen so i bought another and changed it, everything was good until someone rang me and they said they could not hear me?? but i could hear them, but they could hear me when on loud speaker?
is there anything i could try to resolve the problem or is it a bin job?
thanks inadvance
Arran
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
8 Respuestas
Respuesta Más Útil
Just do a quick check:
Does the voice recorder still work, does it record your voice.
If the voice recorder also does not record any voice you probably have damaged the microphone, which you can easily replace by replacing the dock connector (which includes a new microphone).
If the voice recorder does work however you have a major (and known iPhone 4) problem with the noise canceling chip on your logic board, which is unfortunately very hard, if not impossible, to repair.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
hi the voice memo bit does not record any audio??
- de
Replace the dock connector mic assembly. Trust me I do this for a living.
Update
You do have to remove the mic/speaker assembly to change the glass. There are 2 screws under it that hold the front glass on. The top noise cancelling mic works on apps voice memos and speakerphone. The bottom mic is attached to the dock connector and works when the phone is up to your ear.
Puntuación 1
Ic audio broken
Puntuación 0
I'm having this problem with many phones recently, can't understand it?
Puntuación 0
http://m.youtube.com/watch?v=prSZ9yJnofY
Try this has worked a few times for me..
If mic doesn't work when on a call and you can't hear them also this is the fix
Puntuación 0
My iphone has had problems with the noise cancelation mic, does anyone know how to fix the problem... I have iphone 4s
Puntuación 0
thanks inadvance
DG
Puntuación 0
thanks inadvance
Puntuación 0
Añadir tu respuesta
Arran estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 6,428
