Saltar al contenido principal
Segunda generación de iPhone. Modelo A1241 / 8 o 16 GB de capacidad / plástico negro o blanco de nuevo. La reparación es más sencilla que el primer iPhone. Requiere destornilladores, curvas y herramientas de succión.
Preguntas 1145 Ver todo
Pregunta Cerrada
Display not working after reassembly
I have just purchased a 3G back assembly and have just put it all together. As far as I can tell all connectors are in but there is no life in the screen. The phone will connect to iTunes ok and will back up and update but it will not power up. Any thoughts please.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
It may need a hard reset, just pless power and home buttons to power off then power on again, it happened to me when change lcds whit the iPhone powered on.
Fue útil esta respuesta?
Puntuación 0
Hi, i've taken apart my iPhone 3g several times now (got wifi problems) and the first time I put it all back together my screen wasn't working as well. I re-opened it, and noticed that the very last screen connector (the one with the cornered shape) comes loose very easily. Check that connector again, and push it in until you feel or hear a click. Do not lift the screen up again, as it will then bounce up again. It worked for me. Also, before closing the whole iPhone again, turn it on first to see if it has worked, and if not keep trying.
Hope it works for you.
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,100
