iPod won't turn on or off?
My iPod's screen is frozen. It won't turn on/off or anything what could be the problem/solution?
Es esta una buena pregunta?
Press and hold the middle button and the menu button at the same time. This should perform a hard reset and unfreeze the device.
Fue útil esta respuesta?
My iPod has had similar issues in the past, in which even a hard reset would not work. If that is your case, just let it drain itself dead and then charge it back up. You should be good to go then!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,239
1 comentario
Is the little switch on the top in the "Lock" possition?
- de Chris Green
