Saltar al contenido principal
Este modelo de G15 tiene una pantalla mate 1080p que ofrece hasta 360 Hz, procesadores Intel i5 hasta i7 11800H, gráficos UHD de 11ª generación y una tarjeta gráfica GeForce RTX.
Preguntas 4 Ver todo
The laptop randomly wouldn't turn on
In the morning I was gaming on the laptop everything was fine the temps were a bit too high but anyways after I finished I disconnected the charger from the laptop and closed the power outlit (Note: I have two extention cable connected to each other since they are too short) after some time at arround midnight I go back to turn on the laptop I get nothing not even a single light I tried charging it with different wall outlit but still not even getting a single light from the laptop. I can tell the charger is working I even tried a hard reset still nothing. Something I forgot to add is that I allways leave the keyboard and mouse plugged in to the laptop
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
@youssefahme9073 "everything was fine the temps were a bit too high" how high is a bit too high? Tell us more about that.
- de
It was 91°C (While gaming) I don't know if that is too hot but I even did a couple of things on the device before shutting it down so its temps were ok for a while before shutting it down
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
91 degrees is not uncommon for a laptop chassis when under load.
Troubleshooting Steps :
  1. When you start it, try shining a flashlight closely on the display. If the backlight is out, but the machine is somehow on, then you can see a faint image. Although this seems unlikely if there are no lights on the keyboard or indicators.
  2. If you can, try removing the battery and plugging it back in.
  3. Attempt plugging it in without the battery attached. Look for any indicators.
  4. Do a CMOS reset. (Removing the coin cell battery or if it does not have a removable one)
  5. Start disconnecting peripherals and then internal cards. !!!ONLY IF YOU ARE COMFORTABLE!!! The only reason I suggest this, is a unit will typically be able to at the very least produce a POST code or go to BIOS even if the RAM, SSD, and network cards are disconnected from the system. If it cannot do this, then the issue likely lies on the mainboard.
These steps are the basics for troubleshooting a laptop like this.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Youssef Ahmed estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 290
