Front panel broken is lcd?
Front panel broken. Does not work when i tuoch the screen, but it is still active.
Es esta una buena pregunta?
The LCD Display shows the images. If the images are perfect then your LCD is OK. If the front screen is cracked or the touch screen does not respond to the touch of your finger correctly, then this is the Digitizer. If you decide to replace the Digitizer you need a Front Screen and Digitizer for the iPhone 3G. (the 3GS part is different)
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 324
