Saltar al contenido principal
Teléfono de gama media lanzado en septiembre de 2019. También llamado Redmi K20 Pro en China e India. Cuenta con pantalla Super AMOLED de 6.39″, chipset Snapdragon 855, batería de 4000 mAh con carga rápida de 27 W, lector de huellas dactilares debajo de la pantalla, cámara selfie emergente motorizada y una cámara principal con 48 MP más un teleobjetivo ultra ancho de 13 MP y 8 MP.
Preguntas 20 Ver todo
Xiaomi 9t won't make or receive calls
Have done troubleshooting on all software and done a factory reset. I'm also able to make calls with the sim in different hardware.
Any suggestions what hardware needs to be investigated or replaced to fix this issue?
Note - mobile data and SMS still work, just not calls.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
There are several potential solutions to this issue that have been suggested by different sources. One of the most common suggestions is to check if call barring has been accidentally turned on. Call barring is a feature that blocks incoming and outgoing calls, and if activated, it can prevent any calls from being made or received1. It can be deactivated by going into the phone settings and turning off call barring. The default barring password, if required, is usually 1919
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I've tried looking at call barring options but it is not the issue.
- de
Añadir tu respuesta
Alex estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 12
Todo El Tiempo: 112
