Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Una edición mini moderna de Nintendo Entertainment System, lanzada en noviembre de 2016. También conocida como Nintendo Classic Mini NES en algunos mercados.
nes classic won't power on
i bought a faulty nes classic that i discovered won't power on. i checked for voltage with my multimeter and am getting 5 volts at the port and on every component i should be but still no power. what am i missing? it's a european model if that makes a difference
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
5v seems very low for a console
Fue útil esta respuesta?
Puntuación 1
5 comentarios:
5 volts is all it needs since it's the mini and not the og nes
- de Compartir
@techlord yea just checked the power adapter specs, maybe a power button issue
- de Compartir
i checked the power button and reset button with my meter and they're functioning properly
- de Compartir
@techlord any bridging pins in the hdmi port ?
- de Compartir
hdmi port looks fine with no pins touching, micro usb port looks fine with no pins touching
- de Compartir
External Power supply is 9VAC for 1.5A. After the diode rectifier bridge the supply goes to 13VDC.
3 tensions are used from this 13VDC power --> 9VDC, 12VDC and 5VDC this last one thru a LM805 egulator.
As a troubleshooting method you can connect a lab power supply tuned on 13VDC directly on the VIN leg of LM805 the regulator + GND, or on the big capacitor following the diode bridge.
If the console is still dead, the problem is elsewhere.
Puntuación 0
1 comentario:
i don't have it anymore but it wasn't the og nes, it was mini. never figured out what the fault was. when i had it and checked for voltage i was getting 5 volts everywhere i should have but still no power and the switch was ruled out since it did work
- de Compartir
Añadir tu respuesta
Cheap gamer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 61
Todo El Tiempo: 1,143
