loose contact, doesn't switch on
Hello!
due to language difficulties and to make sure I`m on the right track, here a specific question about my computer. ( i am a non technician, but am very good at fixing things myself..., so i want to give it a try!)
my IBM think pad doesn't switch on anymore.
I am quite sure it is a loose contact, since it happened several times during the last few monthes that he switched off by itself, when I moved the computer a certain way. I could easily switch it on again by than. that doesn`t work anymore, he will not switch on! The battery lamp is not on anymore either, when I connect it to the ac adapter.
so, do I need to change the motherboard (as described), or do I just need to find the loose connection to connect it back again?
Thank you!
Almuth
Es esta una buena pregunta?
2 comentarios
update:
the whole problem appeared again when i took my laptop on the next trip 8it's been moved around a lot in that time), but I couldn't fix it anymore by opening and cleaning and closing again. After that it did even strange things: switching on for a few seconds, and suddenly switching off again.
What I did then was simply buying the yellow part mentioned in one of the answers to my question in the first place. I changed the 2 parts, and now the laptop is working well and without any problems again. I am very thankful for this solution after wanting to give up a few times in the process of repairing my laptop and encountering a few problems.
Thanks so much for this lovely page and possibility to get help!!!
- de Almuth
@Almuth, great job in getting it fixed. the credit should go to rj713. Just upvote his answer, since it was the one that helped the most. The upvote will give credit where credit is due :-) Again, great job in getting it fixed.
- de oldturkey03
