Saltar al contenido principal
La revisión de 2016 de Apple a su línea de computadoras portátiles dirigida a usuarios profesionales. Cuenta con una pantalla Retina de 15 pulgadas, 2880 por 1800, Intel Core i7 de cuatro núcleos, opciones de almacenamiento de 256 GB / 512 GB / 1 TB / 2TB, 16 GB de RAM y un teclado equipado con una barra táctil. Lanzado en noviembre de 2016. Características del modelo A1707.
Preguntas 260 Ver todo
Trackpad works but the top layer has detached
On my Late 2016 MacBook Pro (A1707), the trackpad works but the top layer that is visible, is detached on the right side. Is it possible to fix this without removing the battery?
I’m wondering if could mount some double-sided tape underneath the track pad on the right side, not pretty but might work.
Update (12/06/23)
Hi Dan, thanks! CoconutBattery reports: Full Charge Capacity: 95%; Design Capacity: 49%; Cycle Count: 719; macOS Battery Status: Good
Es esta una buena pregunta?
Puntuación 0
1 comentario
Well how about checking the battery as just based on its age its likely its time for a fresh battery. I would install CoconutBattery and make a fresh Question in Answers so we can check it out together.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I’m going to assume this is the original battery, while Cycle Count: 719 is on the edge, the Design Capacity: 49% tells me this battery is not healthy!
So… if you still want to use this system it makes sense to replace the Touchpad and the battery you’ll easily get a good six more years of use!
Review these guides:
Here’s the needed parts:
Imagen de MacBook Pro 15" Retina (Late 2016-2019) Trackpad
Producto
$69.99
Imagen de MacBook Pro 15" Retina (Late 2016-2017) Battery
Producto
$129.99
Imagen de MacBook Pro 15" Touch Bar Late 2016 Batería
Guía
Reemplazo de la batería en la Macbook Pro 15" Touch Bar de finales de 2016
Dificultad:
Difícil
1 - 3 hours
Imagen de MacBook Pro 15" Touch Bar Late 2016 Trackpad
Guía
Reemplazo del trackpad de la Macbook Pro 15" Touch Bar de finales de 2016
Dificultad:
Moderado
1 hour
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
I wanted to replace the battery anyway, but not right now. I fixed the trackpad using two small patches of double-sided tape in each corner, which works well. I'll look at it again when I work on the battery. Thank you for the links; very helpful!
- de
@togedo - I understand it’s a bit of change. In the meantime make sure you backup as one day you might not have access until you fix things.
If your set please accept the answer- Thanks!
- de
Añadir tu respuesta
togedo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 26
