My SWFT electric scooter doesn't turn on. I bought a new charger and i
My electric scooter will not turn on I put in you charger on it and still won't turn on
Es esta una buena pregunta?
You can open it up and get to the battery. Using a voltmeter on the battery will tell you a lot about the problem. If the battery shows nominal voltage, then disconnect it and switch to ohmmeter to trace the wires for an open.
If the charger is good, plugging it in should allow it to turn on. Obviously, you can't ride it that way, but that would indicate an open circuit or a control component failure.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 69
