Saltar al contenido principal
Guías de reparación y soporte para secadoras de la marca Whirlpool.
Preguntas 28 Ver todo
Why is my dryer not heating up.
I replaced the heating element in my dryer and it did fine on the first load of laundry but it isn't heating up again.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios
@jake98574 what is the exact model for your dryer? Besides replacing the heating element what else did you check?
- de
@oldturkey03 the model is a WED4850BW0. the coil for the element had a break in it and the thermostat that is attached was showing it had continuity before I put it on the new element
- de
@jake98574 can you check again and see if your heating element still shows continuity and if the thermostat still has continuity as well?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @jake98574
Here's the wiring diagram for the dryer that may help.
There are two thermostats and a fuse in the heater's operating circuit so you may have to check all of them.
If they all test OK have you checked that there is 240V AC i.e. 2 x 120V AC at the wall power outlet that the dryer is connected to or that the allocated dryer fuses in the house power box are OK? The dryer needs a 240V power supply to work. One 120V supply for the motor and controls and the other 120V supply for the heater.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
jake estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 18
Todo El Tiempo: 81
