First generation of PowerPC laptops Apple manufactured.
Preguntas 3 Ver todo
won't boot from floppy, get error 41 when boot from HD
Here's a question for the "greybeards" out there:
I have a PowerBook 5300c, which when I attempt to boot it normally, gets an error 41 bomb when booted normally or with extensions off. I was running perfectly before I put it in storage a few months ago.
If I attempt to boot from a DiskTools2 floppy, it just spits the disk out and attempts to boot from the HD.
If I attempt to boot from a System 7.5.3 CD, using a SCSI external drive, I get a flashing ? icon, then it fails out to the internal HD.
The boot sequence appears to be correct; the bomb occurs right after the splash screen disappears, as the desktop is being drawn.
Thanks!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
I resolved the issue by formatting the internal hard drive and starting over. As an aside, this model will boot from a third-party external SCSI CD-ROM drive at ID 6. I'm currently about to replace the PRAM battery in this unit, documenting the process for some new guides.
por
Agregar un comentario
4 Respuestas
Solución Elegida
Just curious is the SCSI terminated? If I remember right this was the old key combo for a SCSI start up: CMD-OPT-SHIFT-DELETE-#
the # being the number of the scsi drive.
good luck
Fue útil esta respuesta?
Calificación 2
Comentarios:
if there is only one SCSI Drive, would it be Drive 0 or Drive 1, I know that modern computers start with zero, but does it apply here?
por
The CD drive is terminated, and set to device 6. I will give this a try and report back :)
por
If I remember right you have lost the HD in this system. For some reason the HD is not spinning and will give you the bomb. The system disk for these older computers was different for each one. I used to have them, but they went out, when I moved.
Calificación 0
Im pretty sure that portable macs couldn't boot from SCSI(But i could be wrong, it's been a long time) you might have a hardware related issue such as a bad hard drive, if you can, try checking the drive for clicking noises, and that the SCSI Cables from the drive are ok, im not sure if the cd might be scratched, unreadable, or you may have the 68k version of system 7 designed to run on motorola 680*0 Cpus inolder macs, hope this helps.
Calificación -1
Comentarios:
it does attempt to read the disc in the SCSI CD drive, I will double the OS disc is supposed to boot the old PPC units.
por
Internal was 0
external bus started with 1
Calificación -1
Comentarios:
You should update your answer or add a comment with this clarification.
por
Añadir tu respuesta
David Iwanicki estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 1,204
